Stop leak in system, problems
Old Aug 13, 2005 | 10:25 PM
Bartruth's Avatar
Question Stop leak in system, problems
I added a container of Bar's Leaks Golden Seal radiator stop leak to my cooling system due to a small radiator leak. After about 15 minutes of driving my oil light came on, the temp gauge went into the red and the engine ran rough. After it cooled it was fine for about 10 minutes of driving then did the same thing again. The coolant reservoir is at the corect level. Will stop leak cause this and can it be cleaned out?
Old Aug 13, 2005 | 10:30 PM
zapster's Avatar
my guess is that you put it in while it was hot and now it clogged the thermostat up
thats my guess
but did it work on the leak?
...zap!
Old Aug 14, 2005 | 10:41 AM
dirt bike dave's Avatar
If it were bad enough to clog the thermostat up, it could easily be clogging the radiator passages. That stuff can be dangerous - hopefully you followed the instructions to the letter.
I would try flushing your system to get rid of it. If you still have the leak, find another way to fix it like pulling the radiator and bringing it to a shop to get the pin-hole leak repaired.
Old Aug 14, 2005 | 12:23 PM
Black Hawk's Avatar
i would suggest in going to the shop to get it repaired, ive heard many people saying that its messed up their system and i know they knew what they where doing. both were mechs
Old Aug 14, 2005 | 09:09 PM
Bartruth's Avatar
Thanks for the replies. The only good thing is that it did stop the leak. I flushed the system but it didn't help. Maybe I should try a different flush?
Old Aug 14, 2005 | 11:30 PM
Faster150's Avatar
stop leak causes more problems then is fixes....
Old Aug 15, 2005 | 06:28 AM
PKRWUD's Avatar
Next time try adding some pepper to the radiator. Really.
Take care,
~Chris
Old Aug 15, 2005 | 08:25 PM
Bartruth's Avatar
My best guess and that of my mechanic is that the radiator is partially blocked. Looks like I'll go ahead and spend about $235 tomorrow for a new one. That's the best local price, same at Autozone and O'reilly's. The truck has 155,000 miles with no major problems, still not a bad deal.
Old Aug 15, 2005 | 09:49 PM
zapster's Avatar
maybe you will have the heater core replaced also...try your heater/defroster...
does it blow heat?
if not....
...zap!
