P1131
Old Jul 8, 2005 | 09:56 PM
beenthere's Avatar
P1131
: Help? Went to Auto Zone to run a code on my 99 F-150 4.6 because check engine light came on. Been running rough for several weeks. Was told that this code is a secret code put in by Ford. Can anyone tell me where to cross reference this code?
P1131 : insufficient switching control valve Semsor/Lean
beenthere
Old Jul 9, 2005 | 07:33 AM
phishman's Avatar
I found this site pretty useful
www.obd-codes.com
Old Jul 9, 2005 | 08:37 AM
beenthere's Avatar
Look at the site. Nice, I will try cleaning MAF before looking else where!
Old Jul 10, 2005 | 12:52 PM
Shlep's Avatar
P1131 - Lack of HO2S-11 Switch, Sensor Indicates Lean
A HEGO sensor indicating lean at the end of a test is trying to correct for an over-rich condition. The test fails when the fuel control system no longer detects switching for a calibrated amount of time.
Which basically means the upstream O2 sensor on bank one isn't switching
Old Jul 11, 2005 | 09:42 AM
beenthere's Avatar
Does this meem I should replace the o2 sensor on the manifold or both of them before replacing the MAF.
Old Jul 11, 2005 | 05:56 PM
chris9359's Avatar
I had the same code. I replaced the pasenger side upstream oxygen sensor and it has seemed to fix the problems
Old Jul 11, 2005 | 06:58 PM
JMTruck's Avatar
There is no secret in there. That's the language used by the computer to talk to us or whoever may be interested.
I had a similar problem with the upstream sensor in bank one but changed both of them because of high mileage (111K miles). As soon as I can I will be changing the downstream's, but not in a hurry since there is no trouble code now.
