check engine light on...Help!
Old Jul 6, 2005 | 01:50 PM
todski's Avatar
I need to find out which o2 sensor I need to replace. The code is P0153 (o2sensor slow to respond).
Also do I need a special tool to change it or can I wing it?
97' F150 XLT 3 door 4.8 V8
Thanks,
Todski
Old Jul 6, 2005 | 03:27 PM
dirt bike dave's Avatar
The special tool is a socket with a notch cut into it to allow room for the wires to get out of the way. IMO, it makes the job much easier. I think the socket is about $10 or you may be able to borrow/rent one from Auto Zone.
Not sure about testing for which sensor is good - I ended up replacing both my front ones. Cost about $50 each. I was told it is the front ones you need to worry about, not the rear sensors.
Old Jul 6, 2005 | 05:00 PM
breaker's Avatar
tod when you check the code it will tell you which bank, bank one is the front sensor i believe bank 2 is the back. But they are easily to replace there is a tool to use if you need it I think autozone even rents it
Old Jul 6, 2005 | 10:10 PM
projectSHO89's Avatar
P0153 is the HO2S-21. Upstream sensor, driver's side. Look on the exhaust downpipe before the converter for it.
Autozone will loan the socket for a deposit to cover its cost if you don't return the tool. About $10.
Steve
Old Jul 7, 2005 | 08:04 AM
Johngs's Avatar
If you have a 7/8" wrench that will also work, otherwise just get the socket from autozone, I think it cost me $16 a week or two ago when I rented one, but they refund all your money back when you return it.
Luckily the post-cat sensors are not hard to work with.
