THE H.P FREAK'S "SUPER FREAK" 5.4 BUILD UP!! (pics)
$15000 because he did it 3x. im doing a similar build myself and its coming out around $4700. other wise, your statment is not 100% accurate with the price and ET...
i dunno about you but i dread red lights, or racing of any kind with my 4.6...
Originally Posted by Klitch
hey its tough tho! it took my ring gear bolt being thrown at it and it didnt leak. my oem one got mutilated by them. it may be on the verge of rice but i can see my level at all times AND its tough.
Originally Posted by Neal
HI!... I huess it would only be considered RICE if you had a green neon light inside of it flashing with your sterio bass! LOL!
HI!... Well I've been doing some serious thinking on this project and when the rolling chassis is done, I think I'm going to start FRESH and start another built 5.4 from scratch. Going to go with a custom billet crank, billet "I" beam rods and custom forged pistons, all put into a new FORD NVH 5.4 block. The short block should be good for 1500-2000H.P. Since I'm turning this into a drag truck I might as well crank the boost up as well and see what she'll do. HMMMM 25LBS of boost................
HI!... Any neon light is rice IMO.
aww neal has to revamp his 5.4?
why dont YOU build the motor instead of someone bending you over 3x?
lol just f'n with ya. although, a black light and some white paint might be neat? lol..
I'll assume the cobra 4.6 forged crank is a direct fit for the 4.6 in our trucks?
Can you run a 5.4L crank in the 4.6 without clearancing? Or what clearancing is necessary? Different rods with same deck height?
You'd think the STS turbo kits would have serious lag, but in practice they don't. Watch some of the vids, they spin up real quick.
HI!... Yes the COBRA 8 bolt forged steel crank will fit in a truck 4.6 block.
The 5.4 crank will not fit in a 4.6 block as far as I know. They don't make rods to fit that application. The 5.4 block has a taller deck height than the 4.6 to accomadate the longer stroke and longer rod. Well I've talked to people that have run the STS style kits and there is considerable LAG compared to the typical turbo set-ups.
what they usually charge for building the bottom end? ya can pm me if u have a price.
From Wikipedia:
Contrary to popular belief, the Modular engine did not get its name from its design or sharing of certain parts among the engine family. Instead, the name was derived from a manufacturing plant protocol, "Modular", where the plant and its tooling could be changed out in a matter of hours to manufacture different versions of the engine family.
So just because our engines are "Modular" may not mean that you can use a crankshaft from a 4.6 in a 5.4.
Originally Posted by chester8420
YOU'RE 33 YEARS OLD!!!!!!!!!!!!!!!!!!!!!!!!
I never knew!! WOW! I feel stupid.
