Check Engine Light!!! this are the codes...
Here ya go...I hope ya thank me.
P0354..Ignition Coil D Primary/Secondary Circuit malfunction
U2904...Gotta have the Ford Manual
P1922...Manufacturer Control Transmission
The second one is a network Communication code. Could be intermittent or caused by the 1st code. The tranny code could also be tripped from the ignition problem.
Try clearing the codes, and see if all 3 re-appear.
My guess is that it is just a bad coil pack. Start by checking the connection to Coil D and if it is good, replace the coil, reset codes, and pull codes again.
This should do it......
Good luck.....
Good luck.....
Believe it or not, it is most always good to record then clear codes to see what comes back so old history in not confusing the issue.
It is correct that some faults will trigger the reporting of others because some functions are dependent on others that come before it.
