run away idle
Old May 20, 2005 | 09:20 AM
98Fone50's Avatar
run away idle
96 F250, 5.8 auto, no cruise control. mostly before engine is warmed up, idle comes up to about 1500-1800rpm, even if its in gear driving down the road, at the same time purge solenoid chatters. after a while, problem goes away, no check engine light comes on, and has dtc 212 stored. thanks for any help.
Old May 21, 2005 | 08:14 PM
Robhollar's Avatar
Check your idle air control, the tend to go bad. Or you could have a massive air leak some where...Rob
Old May 22, 2005 | 08:36 AM
Zippy321's Avatar
I had a similar problem on my 98 F150. replaced the IAC and that took care of the idle problem. Good luck.
Old May 24, 2005 | 01:30 PM
98Fone50's Avatar
run away idle
when we unplug the idle control valve, the engine idles down. so we figured the computer must be comanding it on. thanks for responding.
Old May 27, 2005 | 09:15 AM
98Fone50's Avatar
fixed
new TPS took care of it, thanks again
