master flow sensor
Old May 18, 2005 | 10:45 PM
divewithtom's Avatar
master flow sensor
i have a 98 f150 4.6lt 109k miles
i need a master flow sensor should i buy the stock new/rebuilt or should i go with the after market one. would it give me more hp/trq than the stock one?
i need to replace it before i reinstall the hyperteck programmer. what kind of masterflow sensor should i buy (performance one) thanks guys
Old May 19, 2005 | 12:00 AM
Eyescream's Avatar
Mass Air Flow Sensor.
You don't need to buy one of the really expensive Granatelli MAFs unless you're making a hell of a lot of horsepower (think supercharged), cause it'll just cost you a lot of money and not really make a difference.
Just get a rebuilt one and save yourself some cash.
Old May 19, 2005 | 09:30 AM
turbonator ??
does this TURBONATOR replaces the stock master air flow sensor ?? the add that shows on the home page of this website? for $ 69.95 (supercharge your ford) add.
if it is, the cheapest stock rebuild i can find is about $135.
Last edited by divewithtom; May 19, 2005 at 09:35 AM. Reason: price i listed was wrong
Old May 19, 2005 | 09:53 AM
Eyescream's Avatar
Nope. It doesn't replace the MAF; and nope, it isn't worth $70.00 because it's snake oil.
As an aside: Have you tried just cleaning your mass air sensor? How do you know it's bad?
Old May 19, 2005 | 10:58 AM
ford dealership machinic said its running lean (high altitude) at sea level. he said i need a new one. how do you clean it. i will try that first.
see if my pics show up. click on smaller pic to the right.
https://www.f150online.com/galleries....cfm?gnum=3269
Old May 19, 2005 | 12:05 PM
JMC's Avatar
JMC
25 Year Member
The Dealer will not clean your MAF, they will replace it. The Brometric pressure is inferred at part throttle and WOT settings by the MAF sensor. If it is contaminated it will read the incoming air flow incorrectly and that will skew the Baro readings. As has been suggested try cleaning it first. It is in the round box that holds the air filter. I use windex and a Q-tip on the wires. Be very careful or you will break the wire. Here are two articles on cleaning the MAF. Read them both.
http://www.fordf150.net/howto/clean-...low-sensor.php
http://www.stangnet.com/Tech-Article...AF-Sensor.html
If cleaning doesn't help then it may well need cleaning.
Regards
Jean Marc Chartier
Old May 19, 2005 | 03:07 PM
Jordan not Mike's Avatar
You can get a remanufacturered MAF from Auto Zone for less than $60 with a core exchange.
Old May 19, 2005 | 09:14 PM
Eyescream's Avatar
[edited out information that JMC already gave you. I will reinterate that you need to be extremely gentle with those wires, because you're screwed if you break them]
Another thing you could do is try to find a buddy that's got an F150 with similar specs and year model and swap mass air sensors. If his truck starts screwing up and yours starts working correctly, you know the MAF is bad for a fact.
Old May 20, 2005 | 12:09 AM
got it master air flow sensor
i went out and bought the master air flow sensor
let ya know if it worked out
Old May 21, 2005 | 12:26 AM
omg nite and day difference new MAF sensor
oh yeah very nice truck runs great big difference man. then i reinstalled the hypertech programmer III. the truck is unstoppable. now looking in a intake system prob, the k&n full intake w/heat sheild whole kit for $334. can anyone beat that. (does that mean more air more gas?)
Old May 21, 2005 | 02:21 AM
5.4 F150's Avatar
MAF = Mass Air Flow (Sensor). See link for details
http://www.motorcraftservice.com/vdi...ronyms&index=M
Old May 21, 2005 | 03:10 AM
what?
what is your point (link) ?
Old May 21, 2005 | 03:12 AM
autozone
auto zone $90 MAF $45 core
Old May 21, 2005 | 12:53 PM
5.4 F150's Avatar
Sorry divewithtom. Didn't mean anything negative but it's "Mass Air Flow Sensor" not "Master Air Flow Sensor". Just trying to help out w/ link to acronyms
Old May 21, 2005 | 08:44 PM
thanks
thank you
