Distributor
Old May 11, 2005 | 11:51 PM
Meiho's Avatar
Question Distributor
I have a 1979 Ford 300 inline six that has an electronic ignition type distributor and I would like to replace it with a points type distributor. Does anyone know if this is possible?
Thanks,
Richard MacDonald
sangha@netscape.com
Old May 12, 2005 | 11:14 PM
Tailgator's Avatar
Yeah, you can, but why? Fords duraspark II is a fairly reliable ignition system.
Old May 13, 2005 | 12:12 AM
Meiho's Avatar
Smile Distributor
Hi;
Thanks for your reply to my question Tailgater.
The reason I want to change distributors is because I'm putting this engine in a 1964 Ford F-100. i think the wiring would be pretty difficult.
Old May 13, 2005 | 02:25 AM
snappylips's Avatar
Re: Distributor
Originally posted by Meiho
Hi;
I'm lost here. You want to run a points type distributor in a car made for points, right? Where's the difficulty?
SL
Old May 13, 2005 | 12:22 PM
Meiho's Avatar
Wink Distributor
Hi;
This engine came with a Duraspark 11 distributor. But I don't see any reason why a points type distributor won't work.
Thanks for your reply.
Richard
Old May 14, 2005 | 06:08 PM
snappylips's Avatar
Should be no problem at all. All you need is a distributor and coil from a 300 that had points. The wiring should need no mods whatsoever.
SL
Old May 14, 2005 | 06:37 PM
zapster's Avatar
get the points type distributor then install a unilite conversion kit..presto! electronic ignition without the wiring hassels..petronics makes a good conversion kit too(put one in the wifes 200-6 falcon)...zap!
