4.6 5spd check engine
i have a 4.6 5sp and the check engine light keeps going on i went to the dealer to get it checked and they take off the battery conector for a few minutes and no more check engie after 3 days it goes back on weird where can i get one of those code readers ,
Did the dealer give you a code?? Did they tell you what caused the light to come on and why they disconnected the cable to clear it??
Lots of independent shops can read the codes. Or you can buy a reader at a good auto parts store or from a tool man [snap-on, matco, etc]
check engine light
my 98 f150 engine light came on and i went to my local schucks auto supplie ( auto part dealer) free code check found out it was both oxygen sensors replaced it went back to schucks and they cleared the engine light. im thinking about buying a code reader some can cost about $60 more you spend the better it is. updateable. let us know what you find out why its on.
You all will have to notice his location: Manilla, The Phillipines. I doubt that there are any autoparts store sehre that will do what the US-based ones willl, but you never know.
JOEBLACK: Until you are able to get the codes read, we can't help you in diagnosing the reason for the CEL. Get the codes read, write them down exactly (code format is PXXXX where XXXX is a four-digit number), then post them back here for assistance (or SEARCH for the codes).
Reading the codes will require the use of an OBD-II scanner. In the US, these are available at any auto parts store for purchase for USD125 - USD150. Inexpensive ones are available from www.harborfreight.com for around USD 40. You can also try your luck on ebay by searching for "OBD-II Reader"
Best of luck,
Steve
Best of luck,
Steve
CLARK AIR BASE
i was born in clark air base 1964 now living in seattle wa.
buy the code reader you might make some cash there in the pi.
good luck. whatch out for the pot holes. are you a american or pinoy?
