oil replacement
oil replacement
What is a good oil to use in my 2002 SCREW 4.6l in replacement of the Motorcraft 5w-20??
castrol? i think i should go with a semi syn right?
Well, I think it would be a good idea to keep using Motorcraft 5w-20 or an equivalent. The only other maker I know of that has 5w-20 is Castrol, but as far as I know, other makers like Mobil 1 has a 0w-20 that claims to meet the specs of Motorcraft 5w-20. If you are changing the oil yourself and having trouble finding the Motorcraft 5w-20, check your local parts stores. Wal-Mart used to carry Motorcraft (really cheap) but has stopped. Check O'Reilly, Auto Zone, or Advance auto parts (or others in your area). You do not have to get the oil from your Ford dealer. These Triton engines need a good 0w-xx or 5w-xx for a good cold startup. This oil gets to your cylinders and valve train fast when cold, and this is CRITICAL. Also, you will need to be sure to use a good oil filter with an anti-drainback valve, so that the time it takes for the oil to get to those parts is minimized. Of course, Motorcraft is a brand that has exactly that kind of oil filter. I do not know about other filters.
Good luck
Good luck
