2004-2005 FX4 5.4L Oil Filter Change
The original filter can be a bear to get off since it was put on dry, they tightened it too tight and then painted over it. Let the dealer do the first oil change and let them mess with it. After that it's a bit easier, although the filter is in a difficult spot. Turn the steering wheel all the way to the right (or is it left?) to give yourself a little better access.
Rocky My 2001 5.4L was located on the side where you had to turn the wheels This 2005 Filter is located in the lower left front so NO turning of wheels required Thnx anyways and YES Im going to Ford dealer tuesday to have oil changed 750 miles on it I change it at 750 1500 then 2500 . After that every 2500-3000 miles for filter and 7 qts of oil.
