pinging rattling knocking
Old Mar 6, 2005 | 11:41 PM
divewithtom's Avatar
98 f150 xlt 4x4 supercab with a hypertech programmer using 92 octane gas chevron techron the best. and it still pings and rattles when i gun it at high rpms i use the best fuel cleaner. what am i doing wrong? rattles when i pass or just step on it.
Old Mar 7, 2005 | 12:12 AM
Green_98's Avatar
sounds like what probs i had on my 4.6--bad idle, horrible pinging, etc
Cleaned Throttle body, IAC (idle air control) unit, and EGR grooves, and it runs like new
Do a search for all these things and start reading...
Old Mar 7, 2005 | 11:41 AM
PONY_DRIVER's Avatar
Sea Foam IAC and MAF should be cleaned too. My 97 had 117K on it and did the same thing. A little cleaning and it was mucho better. My 01 w/ 72k started to shudder a little at idle and pinged at high RPMs. Sea Foam hooked it right up.
Old Mar 7, 2005 | 12:53 PM
Bluegrass's Avatar
IF....it did it from the time you installed the chip, then the chip is applying to much ignition timing.
Try removing the chip as a test.
Old Mar 7, 2005 | 01:24 PM
dirt bike dave's Avatar
Could be a dirty fuel filter restricting flow. Insufficient fuel getting to the motor can contribute to pinging.
Old Mar 7, 2005 | 10:18 PM
Yankee7985's Avatar
Use Seafoam in the fuel and intake system. Do a search and you will find lots of info.
Old Mar 7, 2005 | 10:36 PM
rngr4x4's Avatar
Pinging
I did the seafoam, cleaned the IAC, and got into the throttle body as much as possible (opened the butterfly valve and used cutips to clean) without taking it off and it still pinged. I will try the EGR and maybe take the TB off when I get time. They didn't have the gaskets in stock at the parts store so I didn't go any farther.
Old Mar 8, 2005 | 09:28 AM
zapster's Avatar
a little 104+ never hurts either...zap!
Old Mar 9, 2005 | 08:37 AM
ncracing6x's Avatar
I had the same problem with pinging but replaced the DPFE sensor (aka EGR Valve position sensor) and it seemed to do the trick. Advance sells them for $50.
