airbag light
Old Mar 2, 2005 | 03:22 PM
peterpan2003's Avatar
Unhappy airbag light
my airbag light stays on no blinking codes just comes on and stays on the passanger switch light will not come on light is good. where is the srs computer located
Old Mar 2, 2005 | 05:46 PM
Faster150's Avatar
worn clock spring mind does it ocassionally when its cold. but take it to a ford house or autozone and see what the codes bring up
Old Mar 2, 2005 | 10:34 PM
projectSHO89's Avatar
Re: airbag light
If the light does not come on, how do you know it is good?
Pinpoint Tests — Air Bag Supplemental Restraint System (SRS)
PINPOINT TEST A: : THE AIR BAG WARNING INDICATOR IS ILLUMINATED CONTINUOUSLY - RCM DISCONNECTED, INOPERATIVE OR LOST/LOW IGNITION FEED
Note:
Normal Operation. During normal operation the air bag indicator will be illuminated continuously for 6 seconds after the ignition switch is turned to the RUN position and after five cycles of a Lamp Fault Code (LFC) if a fault exists. Be sure to cycle the ignition switch and look for a 6 second indicator prove-out without LFCs.
Note:
Possible Causes. An air bag indicator that is illuminated continuously can be caused by one of the following:- Fuses.- worn or damaged indicator shorting bar or camming beam.- damaged ignition circuit.- the RCM disconnected from the vehicle harness.- a loss of RCM ground circuits.- the RCM is inoperative.- circuit.
² A1: RETRIEVE THE RECORDED DTC'S FROM BOTH THE CONTINUOUS AND ON-DEMAND SELF-TEST
² A2: CHECK THE RCM CONNECTION
Check CJB F22.
The RCM is located behind the right side of the instrument panel.
Before screwing with ANYTHING related to the airbags, make certain you are following all safety precautions. If you don't know what they are, refer the servicing to a pro.
Steve
Old Mar 2, 2005 | 10:41 PM
where is the rcm located at in my 2000 f150 supercab
poked around a little but never found it
Old Mar 3, 2005 | 02:56 PM
all fixed
hey you know if it ant pluged in then it don't work
was fixing my tv in my truck and must have never pluged it back in
