High mileage 5.4's with no spark plug problems?
Old May 20, 2010 | 11:59 AM
  #91
F150man21's Avatar
Originally Posted by phillyford99
i had the #7 plug blow out after i changed the plugs. i accidently cross threade the plug but didnt know it and it came out 3 weeks later. trick is to use anti seize and tighten real good.
actually thats not the trick, anti seize is not supposed to be used on the 2v motors
and wow this threads old another
Old May 20, 2010 | 12:48 PM
  #92
Norm's Avatar
Anti-seize can be used if you know what you are doing. You need to adjust your torque by the k factor of the compound you use. If you can't do the math don't use it. It is not needed on our engines with proper Motorcraft plugs.
