throttle body
throttle body
I was wanting to clean my throttle body or replace it with an after market one. what is the best way to clean it I want to try cleaning before i spend the cash and is there any mods i can do to the stock unit? or should i just replace the unit any tips or suggestions please thanks, vuk
For instructions on cleaning the IAC/EGR valves and throttle body, do a search for "Rough Idle Problem" under my screen name (Green_98) Youll find several good pics and lots of good information when i did it on my truck. Makes it run ALOT better when all that carbon is cleaned out
i did it on a '89 f250 with a 460 in it...get a new throttle body gasket before you start...all you need is a can of carb cleaner and a wire brush...take the body off...clean it real good and replace it ...make sure to get all the gunk you can out of the intake plenum also..makes a world of difference!
...zap!
...zap!
