where to get radiator
Any ideas where to get a radiator 2001 screw, 5.4 trans is a 4r70w...........the fitting on the lower trans line is letting water into the trany...........dont ask its a real good oops "Ya play with a snake ya'll get bit"
you could allways bypass the radiator and install a aftermarket trans cooler(if not allready equipped)..if you have a factory cooler just re-rout your cooler lines so you use just the cooler and not the radiator...zap!
Concerning radiator repairs: Ford Motor Company does not advocate trying to repair aluminum core radiators. Replacement is the only option. Some radiator shops will crimp the cores a little tighter, but this is only temporary, and a waste of money. You may gain a few months, before it starts to leak again. Your best bet is to replace it. At our company, we had a radiator repaired with new tanks, but it leaked less than a year later, and had no warranty to go back on. 'Repair' cost was only $15 less than the new warranted radiator. Tough lesson learned.
