Tapping @ Start up
Old Feb 14, 2005 | 12:25 PM
kievitk's Avatar
Tapping @ Start up
Lately when i start my truck up in the morning it has a tapping noise for a minute then fades away. i changed to different weights of oil, and a few other things that might help it but still taps. only in the moring, after that wont hear it till next morning.
Old Feb 14, 2005 | 12:53 PM
Raoul's Avatar
Certified Goat Breeder
25 Year Member
Do a search in this Forum 'Engines'
Use the words 'Piston Slap'
There are 738 posts.
OR
Better yet, don't read them and just forget about it.
Old Feb 14, 2005 | 01:05 PM
TRITON_MOTORS's Avatar
I agree with Raoul. Forget about it.
You'll pull your hair out trying to fight against the noise. Not worth it.
Old Feb 14, 2005 | 07:55 PM
OE812's Avatar
110,000 miles with piston slap and going strong. . .
Old Feb 14, 2005 | 09:36 PM
kievitk's Avatar
well you know i was reading thru some post and found some one talking about noisy metal ball in the metal PCV valve. well i just replaced mine not to long ago. I wounder if that could be some of the noise that i hear. the metal ball rattled up and down in the new PCV valve. The old one i took off was plastic
Old Feb 14, 2005 | 09:46 PM
lees99f150's Avatar
this may cause the noise. buy the ford one. If you still have the old ford one just wash it out with some brake wash and reuse it.
Old Feb 15, 2005 | 12:53 PM
kievitk's Avatar
well i had a big bon fire and was cleaning out my truck one day and just throught it in there. woops
just go to the ford dealership?
Old Feb 15, 2005 | 01:19 PM
WLF's Avatar
WLF
kievitk
Two things come to mind. If it has just started then it is probably another problem. Try using a Motorcraft oil filter and see if that helps. Some of the name brand filters often have failed drain back seals and can cause start up noise.
If it is piston slap then forget it. Mine has been slapping for most of its 178,000 miles without problem.
You should have heard it by now but PS is always worse in the winter with colder temps so you may only just now noticing it...
Old Feb 15, 2005 | 03:46 PM
kievitk's Avatar
thanks i'll have to try a new oil filter.
Old Feb 21, 2005 | 09:17 PM
kievitk's Avatar
how do you know if it's piston slap?
Old Feb 22, 2005 | 09:03 PM
ScrewedUPF150's Avatar
Cold Temperature????????
what is the temperature when you start your truck in the morning? Do you park your truck outside? I had the problem once but it was like 20 degrees outside. That's the only time I have had the problem.
Old Feb 23, 2005 | 02:15 PM
kievitk's Avatar
yes, i park outside and it ranges form 30-45. i guess it just depends.
