Help with occasional starting problem
Old Feb 9, 2005 | 07:21 PM
falcon's Avatar
-- 1998 F-150 4.2 V6 with 96,000 miles.
-- Plugs and wires changed 9 months ago.
-- No arcing seen in dark under hood
Problem:
On two occasions, once in early December and once in mid January, the truck wouldn't strart when I went to leave first thing in the morning. It would turn over fine, but just wouldn't start. After about ten minutes the truck started, sounded crappy (missing) for about 10-20 seconds then ran just fine with no problems.
On about 3 occasions during that time the truck wouldn't start on the first try, but then would on the second or third try. It would then run a bit rough for about 5-10 seconds then would run fine.
Last week drove through an automatic car wash and after passing through the rocker panel / underneath spray, truck gets a slight miss and does so for about 1-2 minutes while in the car wash, then returns to normal.
About a dozen or so times in the last year the truck starts fine but has a slight miss for about a block or so of driving from my house after starting it first thing in the morning.
All problems listed above seem to happen when it is damp outside. Doesn't happen all the time, and rain doesn't seem to affect it, unless there is a high content of moisture in the air.
I want to find out what the problem is now that I have had two occasions that truck would not start (for at least 10 minutes), so I can prevent the problem from worsening.
Any and all suggestions concerning what the problem may be are greatly appreciated.
Thanks,
Steve
Old Feb 10, 2005 | 01:47 PM
01screw's Avatar
When's the last time you replaced fuel filter?
Old Feb 10, 2005 | 03:57 PM
falcon's Avatar
The fuel filter was changed between 3 years ago at 45,000 miles. If it was the fuel filter, wouldn't the problems I am having be less intermittent? The problems I am having don't happen very often, but happen enought for me to feel the need to investigate further.
Thanks,
Steve
Old Feb 10, 2005 | 05:48 PM
01screw's Avatar
First thing I would do is change the fuel filter. Three years ago at 45,000mi, now you have 96,000mi. That's 51,000 miles, WAY overdue! Start with the simple maint. things.
Old Feb 10, 2005 | 08:31 PM
falcon's Avatar
Thanks,
I'll try that.
Steve
Old Feb 11, 2005 | 01:44 PM
01screw's Avatar
That would be the most obvious thing to start with regarding the engine being hard to start. Missing after the car wash was most likely caused by moisture with water being sprayed from underneath.
Old Feb 11, 2005 | 03:03 PM
WLF's Avatar
WLF
I am not familiar with the 4.2 but there have been many instances where a crank sensor failure has caused this intermittent starting problem on the 4.6 and 5.4 engines. If your truck has a crank sensor then replace it. They do not cost much and this has fixed the problem many times for others.
I say this because the discriptions like "only happens some times, only when cold, only when hot" seems to be the norm
