pulley
Old Feb 7, 2005 | 11:50 PM
HarleYEdf150's Avatar
pulley
wuts up guys i was wondering wut i can do to make my harley motor with the same hp as the lighting i heard that u can put a lighting pully on the harley one becuz it boost more than the factory harley one so if u can get back to me that would be great thanks
Old Feb 8, 2005 | 10:40 AM
max mitchell's Avatar
Welcome ! You can change the pulley size on the L or the HD to increase boost. Yes, you can achieve similar, or exceed, boost levels on the HD as the stock L. You need to buy the pulley, have a chip/tuner programmed with the matching proper tune, and change the plugs. You can buy one pulley with a diameter for a given boost level or buy an interchangeable pulley system which allows several pulleys to be exchanged on the same hub for a variety of boost levels. Go read and shop here a while, then give them a call:
www.troyerperformance.com
read the section "Pulleys<Supercharger Overdrive Pulleys"
