engine misses! HELP
Old Jan 27, 2005 | 07:53 PM
joesim76's Avatar
Unhappy engine misses! HELP
I have a '98 f150 with a 4.2l/5spd. For some reason whenever you put much of a load on the engine especially in 3rd, 4th, 5th gears) it will miss/sputter once or twice then take off again and run smooth. I changed the plugs and wires about 20k miles ago and that fixed it for a couple of weeks then it started doing it again so i took it to Ford. they changed a plug and once again it ran fine for a week or two and now it has been doing it for about a year. Any advice? Also im gettin not-so-great mileage 14mpg hwy the engine just rolled over 80k and has not been "hot rodded" do these engines hold up pretty well?
Old Jan 27, 2005 | 11:19 PM
yawr250f's Avatar
If you get a stutter just as you move the throttle and it only lasts 1/2 second or so, it might be the TPS. That'd be the cheapest also.
Old Jan 27, 2005 | 11:35 PM
tl3demon's Avatar
Check your coil if you are having misses and buring plugs it is a possibillity that your coil is going south. Have you done the regular maitence as well Filters etc.
Old Jan 29, 2005 | 12:00 AM
joesim76's Avatar
the truck has been well maintained, new oil and filter every 3k or less miles.
