Throttle Positioning Switch...???
Old Jan 21, 2005 | 04:42 PM
XboxFPSKing's Avatar
Alright I have a 2000 white F-150. Well I went to start it and it would crank perfectly, like usual. But then when it would just suddenly die. I was told it was the Throttle Positioning Switch, so I bought one. But I have absolutely no clue where it's located. I'm hoping it's nothing to hard to install. Any pictures or explanations or even write-ups would be great. Thanks
Old Jan 22, 2005 | 08:57 AM
atsioukl's Avatar
It's probably the IAC (Idle Air Control) that is faily and not the TPS (Throttle Positions Sensor). I would try a new IAC first.
To answer your question, however, the TPS is located directly on the throttle body. It is on the driver's side. Use your new one as a comparison and search for it. It should be quite simple to find.
Old Jan 22, 2005 | 06:33 PM
projectSHO89's Avatar
The problem is because your truck is white.
If it were any other color, it would run perfectly.
Steve
Old Jan 22, 2005 | 06:48 PM
Bluegrass's Avatar
How was it decided the Throttle Position sensor was the fault?
I think you just bought a part you don't need for the discribed problem.
What fault code is stored in the computer?
Old Jan 22, 2005 | 06:52 PM
1Bad97F150's Avatar
Banned
Anyone ever taken off their TPS sensor? I tried to a while ago, and those damn phillips screwdriver heads stripped out.. i mean those screws are in there TIGHT! anyone had to deal with this?
Old Jan 23, 2005 | 10:09 AM
Ted'98's Avatar
Those screws are a royal pain to remove. I'm not sure if the factory applies thread locker or if the screws gaul in the aluminum.
After I stripped the screws, I go the smallest pair of vise grips and little by little, backed them out.
I replaced them with stainless steel alllen head bolts and used some anti-sieze so I wouldn't have to worry about it again.
Old Jan 23, 2005 | 11:27 AM
Umm yeah, actually the truck is my moms. I don't drive it. I have my Honda Prelude. It's my baby. But yeah it was the throttle positioning switch. We installed it, and it cranked right on. So thanks for the help.
