Engine Trouble
Old Jan 15, 2005 | 10:22 PM
vuk75's Avatar
Ok originally check engine light produced cylinder four missfire code so new coil pack was purchased and new plugs, but i purchased bosch so it ran horrible still so some of the sites member suggested the bosch plugs could be a problem so today i checked the coils and replaced all plugs with motorcraft plats double checked all connections and coil connections and still im with my problem as far as the miss goes
at idle you can slightly feel it
when in gear you can feel it
on the throttle it feels horrible no acceleration what so ever
60 mile an hour with cruise on its fine but as far as mahing the peddle forget it
checked coils, checked boots, new plugs
new fuel filter, dry gas, air filter cleaned, checked for vaccum leaks hoses look fine nothing on the block or heads look like its leaking so now what? I must say i do appreciate all the tips and help something has gotta work thanks again
Old Jan 15, 2005 | 10:53 PM
1Bad97F150's Avatar
Banned
bad injector?
possible ECM flash necessary?
Bad wire?
You totally sure that your air intake assembly is FULLY SEATED and properly clamped? any variation from there any part of your air intake is supposed to be covered, sealed, and clamped can cause problems like that... did you make sure you plugged in all the sensors that you may have removed?
Check your fuel pump?
is the SES light still on? if so, what code is it pulling, and did you ever clear the code?
Old Jan 15, 2005 | 11:28 PM
vuk75's Avatar
All sensors double checked tonight after re doing plugs and checking coils, Air intake still the same as i installed it ,it is after market if that would matter in my problem? 1bad you were saying check the fuel pump and the ses light could you please explain this to me
Old Jan 15, 2005 | 11:41 PM
1Bad97F150's Avatar
Banned
well, check to see how much pressure your fuel pump is putting out... maybe its just barely puttering and its causing problems with your ignition... it REALLY doesnt sound to me like that would be the issue, but its a shot in the dark either way... im just tryin to name off everything i can think of that would cause the car to run like that... and lack of fuel could do it... your SES light is your Service Engine Soon... i think on your truck its just a "Check (picture of engine)" or maybe it actually says "Check Engine"... SES is your check engine light what i was saying was, when these cars sense a problem, they re configure their computer to run like that.... so you will need to clear the codes for the computer to reset and work under normal sequence... if not? your gonna have the same issue...
Old Jan 17, 2005 | 11:42 PM
vuk75's Avatar
thanks for the help i finally got it all worked out it was a coil connection problem on the #4 cylinder . Now shes up to full boar again just in time too i was tired of cavaliers passing me. Vuk
Old Jan 21, 2005 | 03:28 AM
vuk75's Avatar
new problem
Does anybody know where I can get the connector from the wiring harness to the coil pack? Ive had a problem with #4 missfire well the problem is the junk plastic connector is split so im gonna need a replacement and to top it all off i found 2 other connections that are cracked on #1 and # 6 any ideas
Old Jan 21, 2005 | 03:40 AM
1Bad97F150's Avatar
Banned
junkyard... or maybe ford has it.. you may have to spring a few extra bucks and just get the entire wire section (which is more probable, because of the pain in the *** it would be to put the connectors inside the plastic retainer) and just cut the wires and solder, or crimp them together on the old wire..... not sure on that one man
Old Jan 21, 2005 | 12:48 PM
vuk75's Avatar
I called my local salvage yards and it was a no go if any body knows of a online salvage yard let me know i would say this has been my whole problem! Think i need my eyes checked Changed plugs 3 times last week and didnt see it ? blind man walking caution, another ? when i turn the o.d. off it seems to run smoother what does the tranny have to do with the coils or is the miss feeling i get possible deeper than the plug wire? I wrench on stock cars from time to time but elctronics and myself dont seem to get along when it comes to my truck but im learning slowly thanks again 1bad, vuk
