died and won't start
Old Jan 2, 2005 | 01:19 PM
flaplante's Avatar
I have a 93 F150 4x4 with a 302. Friday after an afternoon of playin' in the mud, i drive almost twenty miles over some rough logging roads just to have the truck stall in traffic,in town a mile from home. It would crank and almost catch but ended up having it towed home. Full tanks, both fuel pumps working, plugs and wires,rotor and dist cap less than 2000 km old. Any suggestions would be appreciated. Frank
Old Jan 2, 2005 | 09:01 PM
bigbronc's Avatar
Does it sound like a flooded carburetor? Take the red vacuum line off the fuel pressure regulator and see if fuel comes out while cranking. If so, the regulator is blown and needs replacing. Try holding the gas pedal down to the floor while trying to start. It could be flooding out. Check for spark from the plug wires, too.
Robbie
Old Jan 2, 2005 | 09:03 PM
aetcmh's Avatar
fuel injected its a 93
no carb
Old Jan 2, 2005 | 09:05 PM
aetcmh's Avatar
got mud on crank positing sensor
its mounted on side of crank pulley might have mud all over it
Old Jan 2, 2005 | 09:12 PM
Dfunkdf's Avatar
Re: fuel injected its a 93
Originally posted by aetcmh
no carb
then why doese it have two pumps
Dfunkdf's Avatar
no carb
Old Jan 2, 2005 | 09:17 PM
aetcmh's Avatar
93 ford has fuel injection
one on inner driver side frame rail and one in tank ford uses a high pressure fuel system hope this answers ur ?
Old Jan 3, 2005 | 11:58 PM
flaplante's Avatar
died won't start
actually....aetcmh....it seems like my truck does not have that particular sensor or at least I can't find it. and the whole area around the crank pulley is clear ....bout the only spot that wasn't packed with mud! anyway did find one broken plug and one dangling plug wire so put in new plugs then tested for spark....got lots of spark. so am thinkin' maybe it's time to test the computer.
Old Jan 4, 2005 | 12:06 AM
aetcmh's Avatar
i guess im thinking of wrong year i have a 88 f150 off roader and once i unboted the computer there was a little water between the connections
Old Jan 4, 2005 | 12:13 AM
flaplante's Avatar
ok.......thanks i'll try that
Old Jan 4, 2005 | 02:23 PM
wamsleyb's Avatar
check for fuel pressure at the fuel injectors, there is a schrader valve on the fuel rails and they should have something like 40psi on them. You can at least push down on the valve a little bit and see if the gas trys to spray out (a rag would be handy to cover) or if it dribbles out. My dad's 00 f150 would all of a sudden not have fuel pressure and it was some oddball sensor.
Brian
Old Jan 4, 2005 | 03:36 PM
Gmac#1's Avatar
My friends and i have a boat with a mustang engine in it. It is pretty old and has lots of engine problems. Lots of times we will be out on a lake running great and it will just turn off. We try to turn it back on and the engine turns over but it doesnt start. Usually its our fuelpump not working. One of us sucks some gas up to get it pumping and it usually starts up. We are working on getting a new fuelpump.
Old Jan 4, 2005 | 03:39 PM
Gmac#1's Avatar
But i am not exactly sure it will work for you because I am not sure if they are the same.
Old Jan 6, 2005 | 07:38 PM
flaplante's Avatar
found a burnt fuse in the power distribution box...fuel pump feed..so replaced it. then checked the fuel pressure on the fuel rail and no pressure. so now what?
