i hear water in the dash
Old Jan 2, 2005 | 01:04 AM
divewithtom's Avatar
i hear water in my dash just when i take off i hear it trickling but no signs of leaks inside of truck. i thought it might be coolant problems i had it pressure flushed with new coolant and i still hear water trickling, can it be that water made its own resivore
in the outer dash and the drain hole is clogged? do i have to take apart the windshield wipers grille?
98 f150 xlt supercab, 4x4, 4.6 ltr.
Old Jan 2, 2005 | 01:11 AM
lees99f150's Avatar
the AC evaporator drain hose might be clogged. it hangs down under the truck around the bell housing area.
Old Jan 2, 2005 | 08:19 PM
ac hose clogged???
i havent used the ac since july 2004 would the drain hose still collect water when not in use? but hey thanks i will check on that drain hose anyways.
Old Jan 2, 2005 | 08:26 PM
lees99f150's Avatar
when you use the defrost mode the ac is also on to remove the moisture from the air.
Old Jan 3, 2005 | 06:08 PM
BlueOvalFitter's Avatar
The sound you are hearing is the water "gurgling" in the heater core. It does this after you shut the engine down.Its a typical sound on all 97-04 F150s. And,its nothing to worry about.
Old Jan 4, 2005 | 02:10 PM
i hear water still
i only hear the water gurgling only when i eccelerate. and i checked the AC drain hose below and shoved a platic wire about 31 " up into it. what else can it be guys i even had the coolant power flushed.
Old Jan 7, 2005 | 12:09 AM
it getting worse
now i hear water even when i just press down on the gas pedal
its getting worse. theres no water in the cab or any signs of leaking inside. HELP!!!
Old Jan 7, 2005 | 05:06 AM
buckdropper's Avatar
From: south western NYS Latitude: 42.34 N, Longitude: 78.46 W
Run its a tsunami
Old Jan 7, 2005 | 10:24 AM
brahmus's Avatar
how are your coolant fluid levels?? first determine if you are loosing fluid.
Old Jan 7, 2005 | 08:47 PM
Just say "NO"!
Old Jan 9, 2005 | 01:22 AM
its getting worse man
sounds like its getting worse and not low on the coolant either
just can't figure it out. is my heater core going bad and how can i find out. could my heater core hose be clogged and only alittle water is trickling in? is it just time to take the truck to the ford dealer to figure it out? hate to do that! HELP guys
the heater works fine.
Old Jan 9, 2005 | 12:28 PM
help
any more clues on my water problem
Old Jan 9, 2005 | 02:04 PM
lees99f150's Avatar
The area under the windshield cowl isn't full of water is it? My grandma parks under trees and got leaves and stuff in there clogging the drains. what about the map pockets in the door?
