i hear water
i hear water
98 f150 4.6 4x4 supercab
i hear water trickling when i slowly accelerate i hear it in the dash maybe inside of the heater core, sounds like water is trickling in a chamber of sort. doenst sound right never heard it do that before. is it becuz its getting cold out or what? is the heater core going out i have heat and everything works fine all gauges are fine. HELP
foto of my truck is under (divewithtom)
Check out the drip tube on the firewall. it allows accumulated water to drain out of the heater plenum. If cloged it will keep the water in. It is on the passenger side below where the heater hoses enter the cab.
Regards
Jean Marc Chartier
Regards
Jean Marc Chartier
I had the same problem on my '03, and when I took it to the dealership, they were too lazy to work on it, and told me to turn the heater on high and let it run for about 5 minutes, then it should take care of the "sloshing sound." Give it a try if you want a quick fix without disabling anything, it worked for me.
-Lupe
-Lupe
