4.9 broke distributor roller pin? Help
Old Nov 23, 2004 | 09:27 PM
cfhurdle's Avatar
I have an 85 F150 with a 4.9. The engine hesitates on acceleration. The roller pin in the distributor shaft has broken twice. This was repaired with a new distributor, plugs, wires as well as fuel filter. Any suggestions?
Old Nov 23, 2004 | 10:41 PM
Ggg's Avatar
Ggg
Check your dist. shaft for play in the housing, dist. housing for play in the bolck bore, & timming chain for wear. The holes in the shaft and gear might be worn oblong and cutting into the pin. You could also get a solid dowel pin to replace the roll pin.
