4.6 to 5.4 swap
Old Nov 2, 2004 | 05:40 PM
JMC's Avatar
JMC
25 Year Member
4.6 to 5.4 swap
I finally got around to swapping my 4.6 for a 5.4. I started Thursday and it was done Saturday evening. A lot of little things cropped up. Like torn gaskets etc...
It is a totally different truck. The 5.4 has tons of low end torque. Where I had ro rev the snot out of the 4.6 I can just ease off of the clutch and then hammer it and the tires smoke. Mike Troyer is working on a chip to handle the engine tuning and I should have it by some time next week. Any questions ask away.
Regards
Jean Marc Chartier
Old Nov 2, 2004 | 06:58 PM
B-Man's Avatar
Cool
Hi JMC. Long time no speak. Hope all is well.
I was wondering about a couple of things:
1. Did you have a tough time with the transmission ? Does it just bolt-up ?
2. What about the computer ? Was it a big deal with regards to wiring, compatability, etc. ?
I'm not contemplating this, but was wondering for knowledge sake...
Old Nov 2, 2004 | 09:01 PM
JMC's Avatar
JMC
25 Year Member
The bell housing bolt patterns are the same. So the tranny bolts right up. The 5.4 has an 8 bolt crank so if your 4.6 is a Romeo motor it has only 6 bolts so you will have to get the Windsor 5.4 flexplate. My 4.6 was Romeo so I had to find a Windsor flywheel with 8 bolts. I used my 4.6 harness as the donor engine was from an automatic and some of the wires were cut off. If it would have been an Automatic with a 4R70W they would have been compatible. The 4.6 PCM is running the engine with my old custom Chip for now. Mike Troyer is in charge of programming my 4.6 PCM to meet the requirements of the 5.4. It is actually a simple bolt in swap.
JMC
Old Nov 2, 2004 | 10:57 PM
lees99f150's Avatar
so swapping a 5.4 in to a mustang should also be fairly easy. not that i need to, i love my pushrod V8.
Old Nov 3, 2004 | 08:08 AM
JMC's Avatar
JMC
25 Year Member
It is a tight fit but the 2000 Cobra R has a DOHC 5.4.
JMC
Old Nov 3, 2004 | 11:19 AM
2stroked's Avatar
JMC,
Did you stick with the 8.8" rear end or did you install the 9.75" that comes with the 5.4? I'm just wondering how long the smaller rear will last will all that additional torque. Any change in radiator? As I recall, the early 5.4's had a bigger radiator. I've owned a '97 with the puppy 4.6, then a '99 with a 5.4 (PI) and now an '02 4.6 liter The '99 was a killer. Hope all goes well for you!
Old Nov 3, 2004 | 11:45 AM
JMC's Avatar
JMC
25 Year Member
I changed the 8.8 for a 9.75 over two years ago. Even with the 4.6 I managed to break it three times. I changed to a 2 core rad last summer when my 1 core started to leak at the tanks.
JMC
Old Nov 3, 2004 | 10:04 PM
xcr600's Avatar
Doyou get any CEL lights comming on with the stock 4.6 PCM and chip? Could this swap be done and the 4.6PCM used without a custom chip?
Old Nov 3, 2004 | 11:29 PM
JMC's Avatar
JMC
25 Year Member
There are no SES lights at all. There are DTC that are set though. SES is for emissions concerns. I have a P1000 Monitor Testing not complete. P1549 Intake Manifold Communication Control Circuit Malfunction. My 4.6 had the IMRC and the 5.4 doesn't so I left the connector unplugged. And one more that I forget having to do with the knock sensor.
Nothing major. I would not run a 5.4 with a 4.6 PCM unless you take precautions to not tax the engine nore rev past 4000 rpm. The 4.6 will be at its limit for supplying fuel so you will be running lean. You risk melting a piston. Having a chip burned to correct this is essential. I will be getting Air Fuel ratios to Mike Troyer as soon as possible so he can correct any problems. He is sending me a base chip so I can drive it till I get him the required data logs.
JMC
Old Sep 23, 2010 | 05:22 PM
FRod's Avatar
JMC - So the fact that i was using the 4.6 ECU for awhile on stock tune when my Edge was being programmed by PHP, kind of scares me based on what ya said. It was probably pretty stupid on my behalf but i did bring it past 4 grand several times. She seems ok but do you think i burned the rings pretty bad by doing so? Also, with the P1549 code, my 4.6 also had the IMRC, but PHP deleted it and now im getting the code again. What problems could this cause? It is now programmed for a 5.4 aswell on a 93 performance setting and we are having some issues. Let me know what ya think. Thanks!
Old Sep 23, 2010 | 06:07 PM
masterbeatty's Avatar
what would be required to do this swap with an auto trans. i found a 01 pi motor and was hopeing to replace my 97 4.6 with it.
Old Sep 24, 2010 | 05:51 AM
phil6608's Avatar
Did ya try searching in the (how to ) forum?
https://www.f150online.com/forums/ar...wap-notes.html
Phil
Old Sep 24, 2010 | 09:08 AM
JMC's Avatar
JMC
25 Year Member
If the IMRC was deleted in the PCM it should not set a code at all. Your tuner needs to address this. If you still have the valve plug it in and clear the codes. See if the code comes back. I was told by Troyer to not rev the engine so I am passing on that info. As for any engine damage I honestly thing that the PCM would spot a lean condition that is harmful and set a code. I wanted optimal performance so I had a tune done. What issues are you having?
