How far on Synthetic Oil?
Bullitt4711,
This is not a "I disagree" post. Can you give web addressess on this testing you refer to? I have used Mobil one for such a long time that I may be blind to other possibilities but..... I also have 171,000 miles on this truck using Mobil One. I am however openminded to improvements if they are in fact improvements...
The problem with running long drain periods is not that the synthetic oil breaks down it is that fuel that blows by the pistons and other contaminents get into the oil. You should have no problem extending 2x - 3x your oil drains though but I wouldn't go years like people say on the Amsoil websight. Also, I agree with the others and I would stick to Mobil 1 or Amsoil; I would probably use Amsoil if it were easier to get.
Oil Viscosity
Back in 1996 when I was in Technical college(A&P School...aka Jet engine mechanic) we did a Viscosity test to see what oils broke down the fastest....& Quaker State & Pennzoil was the worst...I don't remember exactly what degrees it was, but every oil we tested was all within around 10 degrees form the best to the worst. We tested Mobil, Pennzoil, Havoline, Castrol, Valvoline, Quaker State, & Kendall. We tested no Synthetic oils...& remember this was back in 1996. I believe the order was...
1.Mobil
2.Kendall
3.Castrol
4.Valvoline
5.Havoline
6.Pennzoil
7.Quaker State
1.Mobil
2.Kendall
3.Castrol
4.Valvoline
5.Havoline
6.Pennzoil
7.Quaker State
My Bimmer uses Mobil 1 0W/40 synthetic, and the factory recommended oil change is at every 15,000 miles!!! I of course don't wait that long, because most oil analysis say M1 is useful up to 10,000 miles, so I change at 7,500 miles myself.
As for my FX4, I change with Mobil 1 0W/20 at every 5,000 miles, but I could probably go a bit longer.
brahmus
brahmus, i actually live in minnesota! But, I play in a Cajun band here. We recently won the Prix Dehors award from the Cajun French Music Association in Louisiana. We played at the Blue Moon in Lafayette in August of this year. I have an "Acadian" accordion built by Marc Savoy of Eunice. I see you're from Lafayette. Been there enough times that I'm actually learning how to navigate around that town; no easy task. Obviously, I'm not a Cajun but I enjoy the music.
Visit www.newriversideramblers.com
Bob
Bob
bob,
Bob do you change the oil every trip to Lafayette? Only about a thousand miles, right!
And is the filter hard to get to in your "Acadian". Do you use a Motorcraft?
Sorry, I just had to say something.
Gene
Mobil 1, every 5K, too F150's now, no problems!
Gene
Originally posted by WLF
Bullitt4711,
Bullitt4711,
Just to clarify... Mobil1 is great, and will protect your engine well. Amsoil just offers a bit "more" protection. There are better than Amsoil as well, I just stick with Amsoil for ease, but I am actually looking into putting NEO Synthetics in my 04. Everything I have read rates it higher than others. The ratings are AFSNA(I think...). Will get the info...
Originally posted by Bullitt4711
I have the info, but I cant find it right now. I need to get some sleep, I have a long day of work tomorrow, but I will find it and get it for you.
If you are happy with Mobil1, great! For most people you will get great results! I just am always looking for the best. Who knows if I will ever notice a difference though.
no insult intended but come on man slow down take a breath....edited for content
Re: holy crap
Originally posted by tofer76
can u say wast of money!
the vehicle only had 8k miles after 3 years, so it wasnt getting driven often enough to change it with 5k. Oil does get old.
Plues I get it at cost. Isnt a waste of money to me!
mobil 1 is the way to go.i've ran my truck on it for about 100,000 miles now and it still has exactly 174 psi on all cylinders i change it every 10,000 and it looks the same as if i change it every 3,000 i trusted this stuff in my race car and it never failed me
