Starter question
Old Oct 19, 2004 | 08:32 PM
wolvrin704's Avatar
Starter question
If anyone has replaced their starter please tell me how many mounting bolts there are. I started to remove it tonight but it got too dark while attempting to remove the 2nd bolt. I have already removed the solenoid. The reason I am removing the starter is I've been having startup problems for several months now. At first my battery was draining and I thought I found the problem with my negative cable that had insulation cracked open at the starter. Now that I have removed the solenoid(truck will not start at all now) I found that the grommet wire is broken completely in half probably from corrosion. But I was curious to know how many mounting bolts to know how close I am.
Old Oct 19, 2004 | 10:26 PM
JMC's Avatar
JMC
25 Year Member
You should have 3 bolts. The third one is on the top of the starter.
JMC
Old Oct 19, 2004 | 10:41 PM
wolvrin704's Avatar
Thanks. Thats what I was afraid of. That top one looks like its going to be tough to get out. The middle one is hard enough.
Old Oct 20, 2004 | 06:07 PM
Cruiseomatic's Avatar
On my '89,there was 2 bolted to the tranny,and one screw which held a small wire. When the last bolt comes off,be ready for it,and havea good grip on it,it will drop on you if not careful.
Old Oct 22, 2004 | 03:39 PM
rmeidlinger's Avatar
make your life a little easier. take out the inner fender well. takes 2 minutes but gives good access to the starter
Old Oct 23, 2004 | 12:02 PM
98SCREAMER's Avatar
From: Houston, by way of every major city in America.
Thumbs up
And to the oxygen sensor! If you're in there might as well replace it.,,,,98
