engine modifications.....
Old Oct 13, 2004 | 02:22 PM
mrlucio79's Avatar
Question engine modifications.....
What modifications can i do to my 2001 F150 5.4 engine to gain HP and Torque. I would install a supercharger but I am going to wait on that for a little bit. All advice is appreciated.
Old Oct 14, 2004 | 10:27 AM
max mitchell's Avatar
Stage 1: chip/tuner, air intake system, and exhaust.
Old Oct 14, 2004 | 02:11 PM
brahmus's Avatar
well i'd plan around the chance that you would be eventually putting a S/C on.
Electric fans
maybe some exhaust mods
FTVB (not for power but a must do)
lots of research on which s/c to put on.
then compile a list of must do's to start on the project
Old Oct 14, 2004 | 02:17 PM
BFOR3's Avatar
I'm a newbie also with Ford trucks and I was thinking the same thing. What is a FTVB? Sorry I know everyone prob knows what that is but I need to do it too>Thanks
Old Oct 14, 2004 | 02:21 PM
brahmus's Avatar
no worries Factor Tech Valve Body from Gregg Evans, any vendor here can get them for you. about $225
Old Oct 14, 2004 | 02:39 PM
BFOR3's Avatar
wow great thx for quick reply... what does it do?
Old Oct 14, 2004 | 04:40 PM
brahmus's Avatar
Gregg takes a stock valve body and ports and modifies it with the use of different springs and things that are his trade secrets. in all it shortens the time it takes to go from gear to gear the thing that most gear heads love!!!!
Old Oct 14, 2004 | 11:06 PM
biomed_eng_2000's Avatar
It won't gain you HP but adding an improved tranny cooler is a great start. There's no sense in blowing up a tranny with your blown engine
Old Oct 14, 2004 | 11:16 PM
BFOR3's Avatar
Isn't this what Hypertech Programmer does? reset the shift points? But if this is a tranny cooler then it is definately worth it!!!
Please let me know. Thanks
Old Oct 15, 2004 | 08:11 AM
brahmus's Avatar
two different animals.....well three. the FTVB is not a cooler. The cooler i do recommend but again different mod. and the hypertech usually pumps up line pressure and the FTVB is said to be better on a tranny and provides better shifts in a way that only a Ford engineer could develop. I guess i left that out... Gregg works or worked (correct me if i'm wrong) for ford and has worked on the these trannies. He has access to tools and info that most people don't. Just check out how many Lightnings are runing his FB and you'll be assured this is the right way to go.
Old Oct 15, 2004 | 11:49 AM
BFOR3's Avatar
Got you!!! That sounds great. I have the 4.6L with my expy and when I put on the 22" rims, the truck is just a dogg right now SOOOO....
I was thinking about intake,MAF,header,exhaust,Superchips microtuner, WITH THIS MOD???
This should really help, no?
YOUR HELP AGAIN WOULD BE APPRECIATED!!!
P.S. as far as tranny oil which do you recommend? thx
Old Oct 15, 2004 | 02:12 PM
brahmus's Avatar
throw in a set of electric fans and you've covered the basics and the FTVB will shift better if you like quick firm shifts..
Check your manual but you have to run what is recomended which will probably be mercron V
Old Oct 15, 2004 | 02:17 PM
BFOR3's Avatar
again thanks for your replys!!! I've only fixed up Hondas/Acuras and this is a whole new ball game.
Anyway about the fans, how do I get those and what will they do? Is it a drastic difference? THX, BRAD
Old Oct 15, 2004 | 02:27 PM
brahmus's Avatar
It replaces your current fan with electric fans and is said to give about 15hp. you can search the vendors here.
Old Oct 15, 2004 | 02:30 PM
BFOR3's Avatar
OK GREAT!!! WILL DO, THX AGAIN!!!
