Engine shopping, How to tell 5.4 from 4.6?
Old Sep 15, 2004 | 10:33 PM
69Roadster's Avatar
Question Engine shopping, How to tell 5.4 from 4.6?
Thinking of buying a 5.4 to build up. Say I find a mod motor removed from a vehicle at a junkyard, how can I tell if it is a 5.4 or 4.6?
Thanks.
Old Sep 15, 2004 | 10:39 PM
sporkdevil's Avatar
I would say one of the best ways would be the 4.6 is normal spark plugs and the 5.4 is coils.
Old Sep 16, 2004 | 12:06 AM
69Roadster's Avatar
I thought some later 4.6s had coils too? Guess that's why I'm asking, don't know the difference .
What about Romeo/Windsor engines? Can you tell by counting valve cover bolts or flywheel bolts if it's a 4.6 or 5.4?
Any part numbers (block # etc) I could look at to tell?
Any measurements I could take?
Old Sep 16, 2004 | 12:20 AM
sporkdevil's Avatar
OK, I have no part numbers or anything like that. I can only answer the above to the best of my knowledge. As far as I know, no 4.6's had coil packs. I haven't seen the 4.6l spark plugs, but if they are like some older Ford plugs, it's just spark plug wires over the boots. My coils have yellow "Motorcraft" tops, and a long boot. I'm sure theres more, I haven't changed my plugs for about a year.
And the Windsor engine was for the 351 and such until 96. Don't deem that fact, but I know the Windsor was used until 96, and I have never heard of it on any engine past that year when they switched to the Triton. I would be surprised if there was a Windsor 5.4l or anything to that sort.
I would start from scratch. If you want to build out your engine, you will be replacing a whole lot anyways. You could go the extra mile and get the newer/thicker block, and the best of everything. I still want to see a built, supercharged 3 valve.
Old Sep 16, 2004 | 09:41 AM
JMC's Avatar
JMC
25 Year Member
The IAC on a 5.4 is at the rear of the throttle body elbow. The EGR tube is attached pointing to the passenger side Fender. Have a look at this pic of an intake manifold and you will understand.
Picture courtesy of Neal the Hp Freak
Regards
Jean Marc Chartier
Old Sep 16, 2004 | 12:10 PM
man164's Avatar
The 4.6 got coils packs in 2000.
JMC said about the only way you can tell at a glance.
Old Sep 16, 2004 | 12:14 PM
69Roadster's Avatar
Thanks for the help guys. Much appreciated.
Just to be sure, where does the EGR tube point on a 4.6? Firewall?
Old Sep 16, 2004 | 12:38 PM
JMC's Avatar
JMC
25 Year Member
It points towards the front of the truck.
JMC
One thing to note. All the F-150 Triton engines have the throttle body pointing to the front of the truck. Unless it is a superduty then it is at an angle pointing towards the driver side.
Old Sep 17, 2004 | 10:52 AM
hcmq's Avatar
they also still make the tritons in both Windsor and romeo. do a search here to find which is made where.
also put a call out for neal he should be able to tell you all the stuff you need to know!
Old Sep 18, 2004 | 12:53 AM
svt_sc_f150's Avatar
Ok, first of all there are no 5.4 Romeo engine. All 5.4's are Windsors. The easiest way to tell them apart is to look where the alternator mounts. The 4.6's have 2 bolt holes and the top rail is flat. The 5.4's have 3 bolt holes and the top rail has a drop to it. Sorry I don't know how to post pictures on this site or I would. I have lots of pics of both the engines.
