what brand of spark plugs?
Old Sep 7, 2004 | 11:25 AM
dub24's's Avatar
I have a 01 Scab and have already 62,000 miles on it and I have been wanting to change the spark plugs, however, what brand would be recommended for a little more cleaner burn than just the stock motorcraft ones? any advice would help, thanks
01 4.6 4:10 gears LS
24" Katana Azzad's/ 305/35 kumho
Flowmaster 40 original SI/DO
pro comp 9000 shocks (fr)
pro comp 3000 shocks (rear)
rancho 5000 steering stablizer shock
Hellwig rear anti-sway bar
Moog heavy duty ball joints (upper and lower)
Front A- arm and front sway bar-
polyurethane energy suspension bushings
BBK 75mm TB
BBK pulley set
K&N Kit GEN II
Power programmer III
HD lower valance
HD speed tubes
Viper remote start 791VX
12" Rockford Fosgate subs w/ custom box
1500 watts Rockford Fosgate 501 S
Old Sep 7, 2004 | 11:35 AM
STX/98's Avatar
If you don't mind paying a little extra, I'd go with Denso Iridium's. IMO there as good as you can get as far as quality goes. If the price turns you off, I'd stick with the stock motorcraft plugs. About the only plugs I've heard of anyone reporting problems with are the Bosch +3's, and there are several that have used those aswell with no problems.
Old Sep 7, 2004 | 11:59 AM
dub24's's Avatar
how much are the denso iridiums? and also my buddy has an 01 expy and he put bosch platinum 4's...so I will check the denso's out...thanks for the advice...
Old Sep 7, 2004 | 01:12 PM
STX/98's Avatar
Check with Mike Troyer (Superchips Distributer) in the superchips forum or at (540) 862-9515. I replaced my plugs, wires, and coil packs at the same time, and honesty do no remember exactly what I paid for the plugs alone. You may want to consider replacing all three at the same time aswell just to cover the entire ignition system while your already at it. I believe I later saw where Autozone carried the Denso Iridium's aswell.
Old Sep 8, 2004 | 03:16 AM
worthirt_99's Avatar
I do know that NSK makes a good plug also. They are a copper plug, so you would have to change them every 30,000 again. They worked well in my N/A mustang GT though, it had a 4.6 in it. I believe that I used a NSK-6
edit: NGK not NSK.
Old Sep 9, 2004 | 06:02 PM
BlueOvalFitter's Avatar
Factory Motorcraft plugs!
Old Sep 9, 2004 | 07:30 PM
Pickup Man's Avatar
Autolite platinums.
Old Sep 10, 2004 | 08:31 AM
ccarver's Avatar
NGK TRD5
Old Sep 10, 2004 | 03:32 PM
mlhayes's Avatar
plugs and throttle body/egr
those long plug wire caps a royal pain, especially the back two on each side.
any suggestions on easiest way to remove caps, and access plugs?
also how hard to remove throttle body? got the egr gunked up errors....
thanks
mike
Old Sep 11, 2004 | 12:08 PM
Johngs's Avatar
Some people remove the fuel rail to get better access to the plug holes, but others say you dont have to...I guess it just depends
As for removing the intake elbow, make sure you have a 5/16 socket, several different extensions, as well as a 10mm deep socket. I would also get a long 5/16 in combo wrench, a few cans of intake cleaner (I would say 3 or so), and you should be good to go...do a search, there's a few threads on it here.
Here's a link to another website, this is the process on a 4.6L, it's pretty similar on the 5.4:
http://www.fordf150.net/howto/throttlebodyclean.php
