Highway Speed
Old Aug 19, 2004 | 12:17 PM
patrickj's Avatar
Highway Speed
Hey, New here.
I've got a 2000 Harley-Davidson f150 5.4L.
When I let up on the gas pedal at around 50-60 mph, the throttle realeses but the vehicle motor doesn't slow. The RPM's stay constant as well as the speed for sometimes a couple of hundred feet. Sometimes less. I've had it to 2 ford ealers and neither knew what that problem was.
I appreciate any suggestions.
Thanks.
Old Aug 19, 2004 | 12:30 PM
Johngs's Avatar
I believe its because you are in overdrive and the torque converter is locked up.
Old Aug 19, 2004 | 02:32 PM
patrickj's Avatar
Thanks.
What could be the cause of that?
It started a few months back.
Old Aug 19, 2004 | 02:55 PM
bigtruck311's Avatar
check your tranny fluid to see if it is at the right level
Old Aug 19, 2004 | 04:25 PM
patrickj's Avatar
Fluid level is fine.
Old Aug 19, 2004 | 05:38 PM
check the voltage output on your tps not sure but i think it should be .998
Old Aug 19, 2004 | 06:04 PM
patrickj's Avatar
Bigtruck,
Thanks for your suggestions. It'll be next week before I can get that done. I was wondering, however, wouldn't that have showed a code when I had it in the shop?
Nice looking truck, BTW.
Old Aug 19, 2004 | 08:12 PM
hcmq's Avatar
First off try a reset of the PCM. It will again do what you are descibing as it "learns".
My 99 5.4 did the same thing at around 20k miles and the dealer had to replace the valve body in the tranny and update the PCM.
welcome and good luck-
Old Aug 20, 2004 | 11:10 AM
it might it might not mine didnt when i totaly unpluged it to see if it was cuasing a problem
