6 cyl missing
Old Aug 10, 2004 | 01:34 PM
earl_patley's Avatar
6 cyl missing
91 F150 6cyl is still missing. Replaced the plug wires and had the throttle body gasket replaced. Dealer tells me to replace the entire throttle body. Does anyone else have a suggestion for me? It's like there's a hesitation at certain speeds, used to be only at about 40mph, now it's from 20-70.
Old Aug 12, 2004 | 09:53 AM
RWillieK's Avatar
I've been having the same problem - try the Bosch Platinum+ 2 plugs....its fixed my missfire problems in the past....
Robbie
Old Aug 13, 2004 | 01:16 PM
flaresidejay's Avatar
How long since you changed the fuel filter? Might be a fuel problem just based on speed ranges it occurs in. Also check fuel pressure. Good luck finding the problem.
