Check Engine Light
Old Jul 1, 2004 | 10:32 PM
redcycle13's Avatar
Question Check Engine Light
I'm new to the board and have question maybe someone can help me with. My CEL came on and I had the codes pulled, the scanner said both banks were lean. I replaced the PCV hoses because one of them was burnt up. I had hoped this was the problem so I reset the codes, now the same codes have come back. I recently changed all plugs, fuel filter, and air filter, I also ran a can of seafoam through the vacuum line as directed. I have checked for other vacuum leaks and can not find any. Could someone give me something else to look for before I have to take iot to the dealer. Just for info the truck seams to run fine.
Old Jul 1, 2004 | 11:22 PM
lees99f150's Avatar
make sure the fuel filter is installed correct. the flow or the arrow is pointing forward.
Old Jul 2, 2004 | 11:06 AM
Throttle's Avatar
You might also try cleaning the sensor wires on the MAF sensor located just after the air filter.
