Can't get rid of the Misfire...
Re: HELP!!!!!!!!!!!!!!
Originally posted by LB51
ok...my truck had a rough idle before so i decided to change the spark plugs....i put motorcraft platniums in my truck and gapped them at .054( is that the right gap?? thats what the website for motorcraft said i think) well neways...now my truck is really rough idle and when you hit the gas hard it is very very slugish the truck wont even get past 4 grand on the tach when before with the old spark plugs it would easilly redline....some mechanic guy told me how to put them in and he said not to tighten them to much just tighten them as much as you can with your hand...is that right or should i take a rachet to them?? PLEASE HELP ME I AM IN DESPERATE NEED OF SO ASSITANCE ON THIS PROBLEM!!!!
An update - two days, >100 miles. all types of driving - NO Misfires... What did I do different? I held my mouth just right as I drove.
But seriously, I did not change a thing. Looks like I'll get a coil and try that first, and service the tranny.
I'll keep you posted.
I have the same problem w/ 65,000 on my 2001 f-150 supercrew 4x4 5.4. I plan to try rotating a new coil after reading these posts. This is my first trip to the board.
Sidewinder FX4 - How about that TSB #?
Well I ended up getting a coil and have been swapping it around for the past two days. Yesterday before heading home from work, I swapped it out at #4. I have about a 45 mile trip one way home, so if it was going to misfire again I would know. Well no misfires at all all the way home. I thought I had found the problem until this morning while I was going up a slight incline and it miss fired again! I will continue to swap the coil around. If I can't find a bad coil, I'm going to start looking at the fuel injectors.
This is frustrating especially since it ran fine before my plug change. I have pulled and rechecked spark plugs and gaps twice now. I still may buy 4 new spark plugs and change out a side and see if that fixes anything before pulling all injectors.
Is there any chance it is a bad fuel injector? I'm concerned about driving it in this condition. I don't want to lean out a cylinder and my daily commute is 60 mi. round trip.
Would a lean condition in one cylinder produce a code and a check engine light?
Miss is back. (didn't hold my mouth right, I guess!!!)Started the coil swap tonight. #1 appears to be good. New coil is now in #2. I'll test it on the way to work tomorrow. Carrying tools, too. I'll make another swap in teh parking lot if #2 is OK. Started there because they were easy to get at. Getting the Tranny fluid changed early next week. Anyone had experience with the replacement of fluid by flushing thru the pump? Local joint says that it will take about 45 minutes to flush and replace the fluid. $119 American. Running Exxon fuel to eliminate fuel issue. Fuel filter change to come.
Thanks for your interest. We'll either fix it or blow it up!
I originally replaced my transmission fluid because I thought it could be the problem. They pumped it out just like you explained. Make sure they use the correct fluid. After paying a fortune for the flush, I still had my problem. I took a little more time and watched the tach and decided I actually had a misfire problem.
My personal recommendation is to change the sparkplugs when you swap a coil. The plug change didn't help in my case, but I have read that in some cases that with a bad coil, people are seeing a fouled plug.
In my case I never a saw a code. I'm guessing that the software is set to see a certain number of misfires within a period of time. If that is not exceeded you won't ever trip a code.
I know how frustrating a misfiring engine can be. I hope everyone is able to fix this with the coil. Sure worked great for me!
Coil has been in 1,2,3, & 4. Right now in 4 I have not had a miss in about 45 miles of driving. Going to test for a couple more trips. Don't know how long until I say its OK. I think that I'll put the suspected coil into #1 and see if the miss returns. Replacing the coils at this point is about a 5 minute job!
Still doing the tranny flush and fuelk filter change.
I'll let you know. Thanks for the help...
My miss is gone! Thought I would follow up on what the problem was. After purchasing a new coil and moving it around to all eight cylinders, the truck still had a miss. Yesterday I went and bought 4 new spark plugs and changed out all the passenger side plugs. After over 60 miles worth of driving I have not had a miss and the truck seems to have its acceleration and power back.
Did you change the fuel filter yet? That's the exact same thing that my truck was doing, and I went through several coil pack, plugs and wires before I finally changed my fuel filter and everything was fine after that.
Its back! Worse than ever. After several days of no misses, it starting missing very bad, worse than ever!!!Maybe a trade to a new one will solve this issue...
