Added Horsepower!!!
Old May 18, 2004 | 10:01 PM
LB51's Avatar
Added Horsepower!!!
What are some easy, affordable items that i can bolt on under the hood for added horsepower? I am getting a true dual exhaust system put on with 2 flowmaster 40s....would that add any HP or gas milage? Thanks for any help you can give!
Old May 18, 2004 | 10:02 PM
temp1's Avatar
I think the #1 affordable item would be electric fans.
Old May 18, 2004 | 10:10 PM
Johngs's Avatar
E-fans, FIPK, chip (usually requires premium fuel though)...would be a good start.
Old May 19, 2004 | 09:45 AM
JMC's Avatar
JMC
25 Year Member
LB,
Unless you add headers to the mix you will not gain the max from the true duel. By true duel I mean one pipe for each bank connected from the exhaust manifold going through individual cats and mufflers and exiting through individual tips. If I wanted to nit pick I would also throw in that they have to be of equal length but that is very expensive to do on our trucks becasue of the gas tank.
Regardless if your truck is still stock I would not spend extra for true duels. Find a good cat back system and install that.
The next mod would be a chip or programmer, then an air inlet system like Airforce one. Headers and e-fans next.
Don't forget power pulleys they like the e-fans free up power. I can not use them becasue of the winch on my truck. I need the alternator running at max at as low an rpm as possible to work the winch. As far as the order in which you add them that is open to debate. But as long as you add all of them it doesn't realy matter.
Regards
Jean Marc Chartier
Old May 19, 2004 | 01:56 PM
brahmus's Avatar
give up some details on your ride!!!! engine size, model, year, etc........
Old May 19, 2004 | 02:24 PM
max mitchell's Avatar
edit
Old May 19, 2004 | 02:59 PM
Meyer's Avatar
Chip/tuner, air intake kit, and exhaust. This is phase 1 of most HP per dollar.
What he said, hes the Man.
Old Jun 6, 2004 | 08:36 PM
LB51's Avatar
max mitchell would you recommend i go with a true duals or just buy a cat back system? i the system deep and loud!
Old Jun 6, 2004 | 09:01 PM
edit
Old Jun 6, 2004 | 09:23 PM
LB51's Avatar
yeah but i heard the flowmaster 40 series delta flow stainless steel are loud and deep but they dont come with a system. would you recommend that i go buy the force II system for my truck and then go buy a delta 40 stainless and swap em out n sell the 50 that comes with the system on ebay? Thanks for your help max
Old Jun 6, 2004 | 09:44 PM
edit
Old Jun 6, 2004 | 10:02 PM
LB51's Avatar
I like the look of the dual exhaust out the rear...so you think i should buy 1 muffler of my choice and have it si/do and take it to my local muffler shop and have them custom make me an exhaust. Dont they use Stainless pipes at a muffler shop? would that be the best way to go with this project?
I have a 97 4.6l
Old Jun 7, 2004 | 12:51 AM
edit
Old Jun 7, 2004 | 04:04 PM
LB51's Avatar
I know ive been a pain in the ***...thanks for helping me
Old Jun 7, 2004 | 06:17 PM
LB51's Avatar
lol im bac but only 1 question for ya...ok the muffler im looking at..it has a choice of 2.5" in/ 2.25" dual out or 2.5" in/2.5" dual out which one should i go with to give me the best sound/power/mileage? thanks
