OIl pump draining pan dry
I have a 1995 F-150 which was having low oil pressure. Changed the oil sending unit, oil pump, cleaned the screen and added a manual guage. Great oil pressure when it first starts running and then after while one of the lifters starts pinging. Turned it off and listened and you hear the oil SLOWLY dripping back into the pan. Someone suggested thgat the oil port holes are plugged and recommended taking it to a dealer and having the engine flushed with a Bilstein pump. Will this cure the problem?
