Oil for the f 150 help
Old Feb 18, 2004 | 09:39 PM
Hunter991's Avatar
My dealer is telling me that i should be getting my oil changed there cuz they use the ford semi-syn oil..
It's the same price basically as taking it for an oil change anywhere else. Do you guys suggest using this oil or can i just use regular valvoline. and if i do conventional oil, can you switch back and forth to the semi syn if i want? Will regular work just fine?
what are your suggestions.. thanks in advance.
Old Feb 18, 2004 | 10:30 PM
Dan7's Avatar
This might not help but my advice is change your own oil with mobile 1
Old Feb 18, 2004 | 10:39 PM
Yankee7985's Avatar
I use the same 5W-20 they use, but I buy it at Wally-World.
Old Feb 20, 2004 | 10:47 AM
msparks's Avatar
You would be better off using a full syn. Besides that I've seen pretty good stuff with the Motorcraft 5w20. I would use it before I would use the pennz stuff.
I believe that the motorcraft is made by conoco. The product is called hydroclear and uses a blend of Group II and Group III base stocks. The group III is a hydroisomerized/Dewaxed basestock with a high Viscosity index. I believe in the 140 area. It's a good product but not as good as a real Group IV or V synthetic.
BTW Amsoil's XL7500 line is Full Group III basestock with a really good additive package. You can get that in 5w20 as well.
If it were mine, I would run a full synthetic like Mobil 1 0w20, or Amsoil 0w30.
Old Feb 20, 2004 | 12:09 PM
AWH's Avatar
AWH
Motorcraft 5W-20 Question
I change the oil on my '97 4.6 F150 using Motorcraft 5W-30 religiously at every 3,000 miles (usually every 9-11 weeks). I also buy it at Wally World, where I have seen the Motorcraft 5W-20. Unfortunately, MOST of the driving I do is in stop and go Phoenix traffic and short trips...10 miles or less. Would it be beneficial for my engine to use the 5W-20 synth. blend for this type of driving? I don't want to extend the time between oil changes as I enjoy getting under the vehicle at least every few months to check everything out. I can't afford to go for Mobil 1 etc. but the Motorcraft 5W-20 would be do-able as it is only about 40 cents more a quart. So, my question is, if the oil is changed every 3K, will using the synthetic blend make a substantial difference in my engine's performance and longevity? Thanks oil gurus
Old Feb 20, 2004 | 12:35 PM
98SCREAMER's Avatar
From: Houston, by way of every major city in America.
Thumbs up
For Mobil 1 oil changes I usually get it done at Wally World. I found it's almost ten or more dollars cheaper to have them do it, vs. buying the oil and filter at Autozone. Yes I DO watch them like a hawk also,,,,98
