79F250 300 6 cyl. to 351m engine swap
Old Feb 17, 2004 | 11:20 AM
79f250's Avatar
I have 79 F250 that I've changed the motor in from a 300 6 cyl. to 351m and I can't get the motor to turn over I don't know if I should have changed trans. also or if I should have just changed flywheels but never the less I need help! Any help will be greatly appreciated! I've done some research and it looks to be a c6 transmission.
Old Feb 17, 2004 | 10:35 PM
gearmanx17's Avatar
Can you tell by sound if the starter drive is engaging into the flex plate, or flywheel ring gear?
Old Mar 18, 2004 | 01:41 AM
Flagracer's Avatar
Unhappy
Even if the tranny did bolt on, its likely the 351 will rip it up pretty quick. Being a 250, the frame/suspension PROBABLY are ok but it will still need an alignment for the large increase in weight on the front end. I miss my 79 F250 460, they don't make them like they used to. Also, you may need a larger radiator.
Old Mar 18, 2004 | 02:05 AM
Pickup Man's Avatar
Would changing from the 300 to the 351m require a new bellhousing? Maybe I'm wrong, though.
Old Mar 29, 2004 | 08:32 PM
Flagracer's Avatar
I can't say for sure but I would plan on it
