Zex Nitrous Oxide
Old Feb 4, 2004 | 09:33 AM
zraptor's Avatar
Question Zex Nitrous Oxide
Hello All,
I have a 2000 XLT with a 5.4L Triton V8, i have recently bought a Zex 100HP Dry Nitrous oxide kit and i was curious as to if anyone has ever installed one on their f-150??? Or if anyone knows if it will work or not?
Old Feb 4, 2004 | 02:28 PM
SexpeditionSprt's Avatar
Of course it will work, that is a modest shot for that engine too, it will hold up fine. Just make sure you are getting enough fuel to match the squeeze and you will be fine. That really should wake it up, I'm curious to see how it reacts to a 100 shot. I would not go any higher than a 100 though.
Old Feb 4, 2004 | 03:40 PM
JMC's Avatar
JMC
25 Year Member
What does it use to trick the PCM into adding enough fuel for the Nitrous? As soon as My tranny is fixed and funds are available I want to get their Wet nitrous kit.
It has jets for 75-100-125 hp.
Regards
Jean Marc Chartier
Old Feb 4, 2004 | 04:02 PM
zraptor's Avatar
The nitrous kit uses a computer that detects when the throttle position is at 100% before it starts the injection of nitrous and then as soon as you let your foot off the petal or the throttle position goes below 100% or the air/fuel ratio is too lean it kicks off the flow of nitrous.
Old Feb 4, 2004 | 04:49 PM
JMC's Avatar
JMC
25 Year Member
zraptor,
I want to know where it gets the fuel. A dry nitrous system uses the existing Fuel injectors to add fuel. One way is to trick the PCM into adding fuel the other way is to boost fuel pressure. Which does it use and how does it do it?
JMC
JMC's Avatar
JMC
25 Year Member
zraptor,
JMC
Old Feb 4, 2004 | 05:07 PM
zraptor's Avatar
according to Zex, the nitrous computer goes through the PCM to increase fuel pressure.
Old Feb 4, 2004 | 05:09 PM
zraptor's Avatar
Old Feb 4, 2004 | 05:42 PM
JMC's Avatar
JMC
25 Year Member
zraptor,
That makes sense. The Fuel pressure regulator is vacuum operated and the PCM controls the vacuum.
JMC
Old Feb 4, 2004 | 05:59 PM
dallasscrew's Avatar
Where did you order the kit from. how much time/work to install?
Old Feb 4, 2004 | 06:01 PM
Old Feb 4, 2004 | 06:06 PM
cute, repeating all the messages today.
Old Feb 4, 2004 | 06:13 PM
zraptor's Avatar
I bought it direct from Zex. took about 5hrs to install and on a diffaculty scale of 1-10 id say its an 8
Old Feb 4, 2004 | 06:20 PM
JMC's Avatar
JMC
25 Year Member
Any Impressions afteer squirting it?
JMC
Old Feb 4, 2004 | 06:27 PM
zraptor's Avatar
as a matter of fact i used it for the first time a few hrs ago and it works great, it definetely puts your head in the seat. but be careful, excessive or use in a lean fuel mixture can lead to major engine damage
