Please help
Old Jan 26, 2004 | 12:10 PM
likwidsukr's Avatar
Unhappy Please help
Hello My 4.2 is going south. I owe $10,000 on it. It has 150,000 miles with no previous problems. It has water in the oil. No chance to sell and get another. Have to fix.
1)Should I fix it and wait untill it goes again?
2) Get a 4.6 engine complete with computer and all?
3) Crash truck into tree hope for the best?
What choices do I have
#2 Can it be done easily
Old Jan 26, 2004 | 12:19 PM
Sidewinder FX4's Avatar
Find another 4.2 at your local junk yard. Swap in the whole engine, no conversions-they are a huge headache-----Now trade the darn thing for something with a 5.4 in it!
Sidewinder.
Old Jan 26, 2004 | 12:24 PM
likwidsukr's Avatar
Can't trade they won't do it Tried that route.
A 4.2 ford tuck is almost impossible to find an engine for less than $3000.00 IMO Looked briefly. As I said I will have to keep truck for a while-got to do soething!!!
Old Jan 26, 2004 | 12:31 PM
larryp's Avatar
Rings, new bearings and full gasget set will be easier than dropping in a 4.6L, and significanly cheaper I would think. If it is like all Fords I've worked on, there is probably very little engine wear, but until it's torn apart, no one would know for sure.
Good luck in which ever road you take.
Larry
Old Jan 26, 2004 | 12:32 PM
91F-150302's Avatar
how about a jasper engine. i know a new engine for my Bronco a 351W was only $1800 and you give them your old engine.
http://www.jasperengines.com/
Old Jan 26, 2004 | 12:56 PM
likwidsukr's Avatar
[i]Originally posted by 91F-150302 how about a jasper engine.
Thanks for the replies but Jasper wants $2700.00 plus my old engine I can get a 4.6 online for $1200.00
Is it that hard to do a Convesion on one of these??
Old Jan 26, 2004 | 01:21 PM
bigdr_5's Avatar
I think you should go with Option 3
Crash truck into tree hope for the best. lol
Have you checked the cost of a rebuild?
Old Jan 26, 2004 | 01:24 PM
likwidsukr's Avatar
Yeah it is outrageous!! Man what do I do??
Old Jan 26, 2004 | 01:34 PM
mikemike98's Avatar
If your 4.2 is not making noise you probably just need a gasket or a head and an oil change $1000
$2000 for a light rebuild
a 4.6 may be $1200 but you'll need headers,a wiring harness,
probably a bigger batt., eng. mounts, y pipe , starter,fan,may be a rad and hoses, computer, thottle cable maybe not all these things but as you can see there's a few things to check out.
Old Jan 26, 2004 | 01:41 PM
likwidsukr's Avatar
Mike good info but the motor had most of that with it. O -well I also want more power as well. Damn should of done some research before buying!!!
Old Jan 26, 2004 | 01:47 PM
Raoul's Avatar
Certified Goat Breeder
25 Year Member
You are in a bad situation.
I won't ask why you owe $10,000 on a $4,000 truck.
Your best bet is to find the cheapest way to repair the engine and ride it out.
If you just give up on the truck and let them take it, you will be liable for the difference between the 10K and what they get as is, which won't be much.
The reason they won't trade with you is your negative equity is way too much. If someone owes 6k on a 4k vehicle they will roll the negative 2k into the new vehicle.
As is, your negative is closer to 7 or 8k. That is too much to roll onto the top of a new vehicle price.
You are pretty much stuck fixing it and continuing to buy it.
The cheapest way out is to repair the engine you have.
Someday when you are old, you will look back on this and laugh.
Old Jan 26, 2004 | 01:55 PM
mikemike98's Avatar
I'd go for the 4.6 , parting out the 4.2 should get you $8-900.
Old Jan 26, 2004 | 02:57 PM
likwidsukr's Avatar
I am already laughing LOL LOL ROTFLMAO!!!
Old Jan 26, 2004 | 09:08 PM
03f150man's Avatar
if you are going to keep the truck your only viable option is to fix it, or install a rebuilt 4.2. the 4.6 route is too expensive.
Old Jan 27, 2004 | 01:25 PM
likwidsukr's Avatar
Thanh you!! That is what I was after
