maf
Old Nov 16, 2003 | 06:10 PM
pstmn1's Avatar
Question maf
Ok new to playing with fuel injected vehicles but not new to playing with engines of the carburated type. I was going to clean my MAF but guess what, could not find it to clean it. I had the the air tube and cleaner off exposing the throttle body butterfly , worked the butter fly to spray in some FI approved cleaner and could not find the MAF. Help. Also, I was having a problem with rough idle but after the sprying it cleared up.
Mike
Old Nov 16, 2003 | 07:39 PM
roland constabl's Avatar
maf's
the mass air your looking for is in the tube between the throttle and the air cleaner, there should be a small harness plugged into it, just becareful with the small wire in the mass air sensor
thats what monitors air flow, good luck with the fix
Old Nov 17, 2003 | 08:30 PM
pstmn1's Avatar
maf
thanks roland will try to locate it on wednesday
