rpm
Old Nov 12, 2003 | 07:11 PM
QuiK's Avatar
rpm
what should my rpms wbe when i start my truck? and its in park? and what should they be when im @ a stop sign? i knwo they allrange but whats abnormal? at first when i cleaned my egr valve i was like @ 1000 and @ stop signs like @ 600 or so. but now on start im @ like 800-900 is this to low? can u change it? whats the effects? im driving a 4.6 f150
Old Nov 12, 2003 | 07:17 PM
Johngs's Avatar
It depends on the weather. On cold mornings, my RPM right after start (and until its warmed up) are a good bit higher (not sure of the numbers sorry).
When the engine warm, mine idles around 600 in drive, and about 700 in P or N.
On warm days I would say right after start it idles around 800-1000 RPM until I put it in drive, and after that it is pretty much like the numbers above.
Old Nov 12, 2003 | 08:32 PM
Luser's Avatar
My 2000 F150 (Manual) idles at around 850.... As for changing it, probaly not (depends on year and so on), that would be a shop manual/dealer question, but I can offer this advice, under the hood on the emission sticker it SHOULD say the idle RPM.... I know it does on my although that may be a function of being in Cali. :o
Old Nov 12, 2003 | 08:38 PM
Johngs's Avatar
Emission sticker?
Where's that at?
Old Nov 13, 2003 | 02:55 PM
QuiK's Avatar
great guys thanks, i thought it was low or something i was worrying but u sem to be in my range or near it thansk for info giuys
Old Nov 16, 2003 | 01:13 AM
sleeperlover's Avatar
my 91' F150 5.0 302 idles at 650, when in park and N, and when in drive, it idles around 600 when warm. I have been told in my yrs that n e where from 600 to about 750 is best at idle. But it depends, if u find that when u kick the air cond. on that it idles below 650 or 600, then u should kick it up.
One way that u might try to idle up, im not sure that ford has this, but, where u throttle cable comes out to, on other makers there is a screw to pull the throttle out, and to loosen it. U can try and set the idle higher by pulling the accelerater out wth that screw, i had to do it to my 85' Buick Park Avenue when i had it.
I hope this helps in some way.
Old Nov 16, 2003 | 03:41 AM
F150Europe's Avatar
Arrow
https://www.f150online.com/forums/sh...hreadid=128204
