More Power
Old Nov 11, 2003 | 03:44 PM
1993F150's Avatar
More Power
I have a 93 F150 with a 302 and would like more power. The book says that I have 185HP now. Can I put is a roller motor and gain very much? Or put a turbo on the engine that I have? Any suggestions?
Old Nov 11, 2003 | 03:58 PM
johnny_rotten's Avatar
How much power do you want from your engine? Is it a daily driver and is idle quality important to you? What about fuel economy, and how much $$$ do you want to spend?
Old Nov 11, 2003 | 04:04 PM
1993F150's Avatar
Yes it is a daily driver. My mileage isn't that good now, but would like to improve if possible. I don't have a figure in mind, just getting some ideas.
Old Nov 11, 2003 | 04:16 PM
Fastest and easiest way to go would be the addition of a supercharger. The initial cost is a bit high, but you will maintain the drivability and fuel economy of you engine as long as you keep your foot out of it! With a small charger like a vortech a-trim you'll probably pick up around 50-70hp roughly and would not cause a whole lot of stress on your engine.
If your just looking for the occasional blast of acceleration nothing beats NOS, and it's reasonably cheap. you can also jet a NOS system for how much of a kick in the pants you want, anywhere from 50hp right up to 300+ hp!!! The 50hp kit would be safe to run easily, but you may only get one use out of the 300 kit.
Or just go for a basic rebuild and add a few goodies while it is in the shop (or do it yourself) like the addition of aluminum heads, swap out your cam, etc.
Hope this helps.
Old Nov 11, 2003 | 04:25 PM
1993F150's Avatar
thanks for your input. The main reason for the extra HP is for pulling a trailer.
Old Nov 11, 2003 | 04:33 PM
You truck is fuel injected and mass air right?
If you went with a basic head + intake combo you would probably be happy. The stock ford truck cams are great for low down grunt so I probably wouldnt change that. A nice pair of Trick Flow, Edelbrock, or AFR heads, and matching intake like a Edelbrock Street heat would do it for you fer sure.
This is what I use my extra power for https://www.f150online.com/galleries....cfm?gnum=3326
Old Nov 11, 2003 | 04:45 PM
Ervin's Avatar
A simple fix may be to have it de-carbonized and check to see if your using motorcraft plugs and have a good rotor and cap. That improved my HP and mileage. About 80 for the de-carbonizing of injectors and intake. Good luck.
Old Nov 12, 2003 | 07:01 AM
1993F150's Avatar
does the dealer do the de-carbonizing? I have fuel injection ,but I don't think that I have a mass air. Something else I bought a ram air hood for it , but don't have it on yet. Thought that might help.
