uhhh...IAC?
Old Nov 10, 2003 | 04:04 PM
Johngs's Avatar
uhhh...IAC?
ok...I was looking for my IAC today. Ive seen plenty of threads here.
From what I have gathered, it is on the driver's side (?) right next to the throttle body.
Which means it should be here:
But I dont see any "canisters" there.
The other side of the TB has nothing there in terms of canisters with wires coming out.
This thread from search:
https://www.f150online.com/forums/sh...=clean+solvent
Says it is on the pass. side, but that is a lightning and mine (obviously) does not have the blower or SC.
Im lost...where is my IAC?
Old Nov 10, 2003 | 04:11 PM
grinomyte's Avatar
see that black tube over on the right side of your picture that you pulled from the intake? That goes to the drvier side cam cover. Right above(or is it below?) where you disconnected that, there was another tube you disconnected off the intake, that goes to a baffle box, and then to your iac.
Old Nov 10, 2003 | 04:28 PM
Johngs's Avatar
Ah, ok.
Yeah I was holding that other tube up with my hand and it was the upper one.
Ok so it's BEHIND the TB. Gotcha.
Thanks.
Old Nov 10, 2003 | 05:01 PM
temp1's Avatar
How did you get that picture in your message?
Old Nov 10, 2003 | 05:10 PM
Johngs's Avatar
Upload a pic to your gallery.
When viewing the pic, there is a little link that says "forum codes". Highlight the one that says "fullsize image" and copy it. Then paste it into your message.
You can also copy the one for thumbnails for a smaller image.
Old Nov 10, 2003 | 05:31 PM
temp1's Avatar
Thanks Johngs, it worked! Muahahahahah...
