Drain plugs on the engine block
Old Nov 4, 2003 | 03:04 PM
temp1's Avatar
Question Drain plugs on the engine block
I plan on doing a coolant flush and removeing the drain plugs on the engine block.
Is there some sort of dope or sealant I should put on these plugs when I put them back in?
Old Nov 4, 2003 | 03:07 PM
grinomyte's Avatar
i hear loctite.
Old Nov 4, 2003 | 07:31 PM
temp1's Avatar
Thumbs up
Thanks.
I could not find that Loctite PST. Advance Auto parts had Permatex "Hylomar HPF" gasket dressing and flange sealant. The package says it is suitable for use on Cylinder block plugs.
Old Nov 4, 2003 | 07:34 PM
grinomyte's Avatar
i see locktite all the time at kragen's and autozones and pepboys, don't know if you have those where you are.
Old Nov 4, 2003 | 09:18 PM
temp1's Avatar
Advance auto parts had all kind of Loctite stuff. I could not find anything with the "PST" on it.
Old Nov 4, 2003 | 09:19 PM
03f150man's Avatar
i just snug the drain plug without using any kind of loctite or other adhesive and have never had any leak.
Old Nov 4, 2003 | 11:53 PM
tkarter's Avatar
The block drains are tapered pipe thread. That means they will seal without help and don't have to be torqued down like a head does.
I would use a 3/8 ratchet and when it felt snug quit. I would bet it won't leak.
IMHO
tom
