How do you clean the iac ??
Old Oct 27, 2003 | 03:45 PM
rangerr91's Avatar
Unhappy How do you clean the iac ??
Ok,I will try and clean it but where is it and how do you do it on a 99 4.6 ???
Thanks Guys
Old Oct 27, 2003 | 03:49 PM
grinomyte's Avatar
pull it off, there will be a gasket and two holes, slip the gasket off, spray the inside with wd-40, then use carb clean (least thats how i did it, ive heard just carb clean but wd40 seemed to make it run better, but use the carb clean to get all the grease out.
If you dont know where it is. The iac lets air bypasss the throttle plate. So just look at your intake tube and see where it branches off and goes back into the throttle body. Its a silver cylinder about 1 IN in diameter and about 2 inches long. Has an electrical connter attached.
