why does my 99 4.6 quit while idiling durring warm up
i too vote iac, idle problems that stall are typically the IAC or vacuum leaks. I cleaned mine which helped. Take it off, wd 40 first, then carb cleaner. Put it back on. Clean the MAF too while your in there and check your vacuum tubes, esp the one from the passenger valve cover to the rear of the TB, those like to break and crumble.
