Insufficient Torque
Old Oct 25, 2003 | 10:27 PM
ihilani's Avatar
Unhappy Insufficient Torque
Help.
My 97 f-150 has been losing torque slowly but surely over the last few years. I have taken it to the shop and they tell me everything is okay and find some other things to fix and charge me for.
Lately, I'm having a hard time pulling out from stop signs and dread an uphil stop that I must make on the way to work. Pulling my 20 foot boat out of the water now requires a shift into low range to get adequate torque.
My truck is stock and the only modification is a KN air filter and upgraded 245x75x16 dunlop revo's.
I've already tried spraying the MAF sensor which helped a little, but I still don't have enough torque to back my boat up the slight incline to the garage without using low range.
What can I do?
97 F-150 SCab, 4x4 with 4.6 and 5 spd manual, 3.55 rear end.
Old Oct 26, 2003 | 01:32 AM
Pestco1's Avatar
If cleaning the MAF helped maybe you should look into replacing it.
Old Oct 26, 2003 | 01:36 AM
Neal's Avatar
Cool
HI!... Check your CATS. Last year my truck was slowly losing power until when floored it felt like a V-6!!!! I found that one of my CATS had fell apart internally and plugged up the secondary CAT almost completely. Check your CATS.
https://www.f150online.com/galleries...-793-23378.jpg
https://www.f150online.com/galleries...-793-23375.jpg
https://www.f150online.com/galleries...-793-23376.jpg
https://www.f150online.com/galleries...-793-23377.jpg
Old Oct 26, 2003 | 01:48 AM
Pestco1's Avatar
Neal made a good call. Sometimes they melt inside and plug up. really causes a power loss. Most muffler shops can test them to see if they are working
Old Oct 26, 2003 | 01:46 PM
ihilani's Avatar
Smile
Hello all,
thanks for the feedback.
Last night, I read some old threads and made a late-night run to wal-mart to pick-up a standard fram paper filter and a can of brake cleaner.
I shot the MAF, changed the filter, disconnected the battery for 15 minutes, and then let everying idle for 10 minutes.
WOW what a difference. The power is back. I will also have my CATs checked to see if there is more power to be had.
thanks for all your help.
aloha,
ihilani
